Solar Motion Sensor Light With Gooseneck Wall Mount
Brighten up areas around your home at night in cost efficient fashion while making them look good and more secure with the Gama Sonic Solar Barn Light Plus Motion Sensor. This solar shed light will give off a bright light without using electricity since it runs on solar energy, preventing you from incurring additional charges on your monthly electricity bills while enjoying high quality lighting. At the onset of darkness, this LED solar light will conveniently turn on by itself to illuminate its immediate surroundings. Once there's movement within 15 feet in front of it, it will boost its light output. By giving off a brighter light, this solar powered motion activated light informs you that there are people in your property and helps you identify them. The increase in light output can also scare away intruders late at night by creating an illusion that someone has noticed their presence. Endowed with a gorgeous design, this LED solar light also functions as an effective decoration as its timeless look is ideal for adding elegance sheds, garages, storage units and greenhouses. Light dimensions: 12" x 9.5" x 10" (LxWxH). Frame material: Cast aluminum. Lens material: Glass. Light source: 6 Bright-White LEDs. Continuous light output: 75 Lumens. Motion-sensing mode light output: 150 Lumens. Maximum motion detection range: 15 feet in front of the fixture. LED temperature: 6000K. Battery: 3000 mAh rechargeable Li-ion battery. Maximum operating time: 10 hours. Power source: Monocrystalline solar panel. Solar panel dimensions: 7" x 7" x 1/2" (LxWxH). Solar panel wattage: 2 watts. Manufacturer warranty: 1 year.
Price: 89.00
© 2018.
