Solar LED Dual Security Motion Sensor Spotlight
Keep your home and out door areas more secure at night with the Solar LED Dual Spotlight, a very bright solar powered motion activated light that will automatically cast superior lighting on your outdoor areas once its senses motion after dusk. With each of its heads wielding super bright SMD LED, this solar security light can cast high quality lighting on your garden, lawn, patio, yard, driveway and other outdoor areas during darkness. The light generated by the Solar LED Dual Spotlight is ideal for identifying people and detecting unseen moving objects at night. Designed with motion and light sensing technologies, this outdoor solar motion light will conveniently self-activate once it picks up movement after dusk to notify you whenever there is movement around your house. Finish: White / Dark bronze. Fixture material: Durable plastic. Dimensions: 8" x 5.5" x 8". Light source: Super bright SMT LED. Battery required: 3 rechargeable Ni-MH batteries (included). Motion sensor: Yes. Maximum running time: 150 times, lights up whenever it senses motion after dusk. Light duration: 10 seconds to 1 minute (depending on the duration set by user). Weatherproof: Yes. Weather rating: IP44. Manufacturer's warranty: 1 year.
Price: 64.89
© 2018.
