Premium Modern Solar Wall Light - 6 Inch Wall Plate Diameter
Go beyond wall lighting with the Premium Modern Solar Wall Light. Equipped with 36 Hi Power Bridgelux LEDs, this solar light for walls does more than accentuate its immediate surroundings with aesthetic lighting. Crafted with a distinct design, it works as a wall decor just as well. Completely wireless, this bright solar wall light can be easily mounted on smooth surfaces with or without an electrician's help. Lastly, this solar LED light helps you maintain the curb appeal of your home day or night with its accent lighting without incurring additional charges on your monthly electricity bills. Dimensions: 15" (Height) x 10.13" (Top Diameter) x 4.75" (Bottom Diameter). Light Source: 36 x Hi Power Bridgelux LEDs. Color Temperature: 6000K (Cool White). Light Output: 252 Lumens. Battery: 6V/ 4.5 AH sealed lead acid. Maximum Operating Time: 13 hours. Solar Panel: 4W monocrystalline silicon. Frame Material: Cast aluminum. Waterproof rating: IP65. Manufacturer Warranty: 2 years.
Price: 179.99
© 2018.
