Maxsa Aluminum 80-LED Solar Motion Detector Light
Setting up solar security lighting around your home is finally easy! No need to pay anyone to install expensive wiring because a Solar Motion Detector Light doesn't need household electric, it uses only the power of the sun. Maxsa Innovations, a leading manufacturer of solar security lighting, has done it again! The Maxsa 40227 Aluminum 80-LED Solar Motion Detector Light now made of durable aluminum provides both a weather resistant finish and a nice sleek look. The best thing about this solar motion detector light is the ease of installing it. Simply surface mount the security light fixture to a flat vertical surface, plug the wire of the light fixture to the wire of the solar panel with the easy connecter plug, mount the solar panel, then enjoy the added security around the house and the free energy from the sun.
Price: 99.99
© 2018.
