Dock Edge Aluminum Flush-Mount Solar Accent Light for Nautical Docks & Decks
The Dock Edge Aluminum Flush-Mount Solar Accent Light is a premium choice for your outdoor lighting needs. The Light automatically turns on at dusk and is a compact size that works perfectly with any walkway or landing. This light features a simple, wireless installation with an easy to replace rechargeable battery.
Price: 35.99
© 2018.
