8 Piece Residential LED Solar Spotlight Landscape Lighting Kit with Stakes Get a convenient and superior lighting solution for a multitude of outdoor areas with the 8 Piece Residential LED Solar Spotlight Landscape Lighting Kit with Stakes. Composed for 8 solar spotlights for yards, gardens, lawns, driveways and patios, this solar landscape lighting kit will allow you to greatly improve visibility in multiple areas outside your home without paying an electrician to run wires. This solar landscape lighting kit is composed of eight solar garden spotlights that automatically gather solar energy during the day in order to acquire the power it will need to operate all night and brighten up dark areas without consuming electricity. Devoid of wiring, these solar spotlights yards, gardens, lawns, patios and driveways can be easily installed in areas outside your home without a the aid of an electrician. If you add your savings in electricity consumption and from not hiring an electrician with these solar powered lights, you'll realize that these are among the best solar spot lights for those who want a cost-efficient lighting solution. Light Housing Construction: Cast aluminum, powder coated black. Stake Construction: Heavy duty PVC with 1/2" NPT threading. Light Source: 16 x Super Bright LEDs (2 per light). Brightness Equivalent: 8 x 8-10 watt halogens. Battery: 1500mah 3.6V NI-MH battery pack per light (included). Run Time: Summer in direct sunlight 8-10 hours/Winter in direct sunlight 6-8 hours. Manufacturer Warranty: 1 year. Price: 258.99 |
