54-LED Motion Activated Solar Light - SGG-PIR54
With 54 LEDs, the Motion Activated Solar Floodlight - SGG-PIR54 can help make your neighborhood much more safer. This solar security lamp can throw light on areas where it senses motion, helping you determine if there's something serious going on. This solar powered lamp with motion sensor can pick up movement from a distance of 30-45 feet. Under a full charge, this solar outdoor light can operate for up to 120 minutes and will automatically light up for 1-4 minutes once it detects motion or stay activated as long as there's movement. Should you wish to operate it manually, this solar security light is built with a power switch that can be used for manual operation. Dimensions: 12" x 6" x 9". Solar panel cell type: Monocrystalline. Battery type: Lead acid. What's included: Motion Activated Solar Floodlight - SGG-PIR54, Monocrystalline Solar Panel, 9-foot cable, battery, case, PCB, connectors and wires. Manufacturer's warranty: LED - 3 years / Solar panel - 1 year / Battery, case, PCB, connectors and wires - 90 days
Price: 99.99
© 2018.
