28-LED Motion Activated Solar Light - SGG-PIR28
The Motion Activated Solar Floodlight ? SGG-PIR28 detects motion within 30-45 feet and automatically throws light at whatever is moving with 28 LEDs, making it a convenient solar security light for you and the rest of the neighborhood. This solar powered lamp with motion sensor draws power from the solar panel that comes with it. The solar panel can be placed up to 9 feet away with the included cable to allow for flexible placement and installation. Under a full charge, this solar outdoor light can run for up to 120 minutes and will automatically light up for 1-4 minutes once it picks up motion or it'll stay lighted as long as there's movement. Dimensions: 8" x 6" x 7". Solar panel cell type: Monocrystalline. What's included: Motion Activated Solar Floodlight - SGG-PIR28, Monocrystalline Solar Panel, 9-foot cable, battery, case, PCB, connectors and wires. Manufacturer's warranty: LEDs - 3 years / Solar panel - 1 year / Battery, case, PCB, connectors and wires - 90 days.
Price: 69.99
© 2018.
